Engine Coolant
durhamjohn
has anybody found an easier way or modification to fill the water tank with out removing the rear cowling & seat ?
sentenal 333
is your bike loosing coolant? you shouldn't have to top it up. mine has done 40000km and hasn't lost a drop(I did just change the coolant and brake fluid
for its 40000km service) if you think the coolant is in a bad place try topping up the rear master cylinder fluid without stripping the bike.
I used a syringe with a rubber hose to top off the water tank under the bike. (Have to remove the fill hose first though which is EASY!)
durhamjohn
no it isn't losing water, it took me 20 minutes to remove 4 clips, 6 bolts, & pulling plastic apart to put water in on my first long ride of the year, its only a matter of time before something breaks or weakens by pulling it all apart. for about £5 i can erase all that by moving the filler cap !
Y2c
Just a funnel and hose saves any need to dismantle anything. I've had no need to refill in over 6 yrs.
Vladislav
В долгой поездке, порядком 2000 км. Заправлял 4 раза по 1 литру. Думаю это перебор, так не должно быть. Мотоцикл грелся часто.
