Botanikman
I have a 2009 DN-01 that has about 25,000 miles on it. In summer heat when 98 or higher - esp. at red lights - it starts fluctuating below the norm of 1100 RPMs and may choke down. In winter, often idles too high to switch between N and Drive. I wondered it if might be related to a bad Air Charge Temp Sensor or some other sensor. Changing plugs and wires did not seem to help. In summer, using Seaform and ethanol free gas seems to keep from choking down at red lights. I live in SE GA which is hot in summer.
Last year had to replace right hand side handlebar switch assembly as when got least bit wet, kill switch seemed to short out D/Neutral switch and it would not start. Temporary fix before replacing was to use WD 40 spray. I do not think this is related to the problem I have now. Got bike when had 17,000 miles w/o a problems. Any helpful thoughts would be appreciated.
