How is the spring be tensioned?
shaunx
Hello there,
For t stunt what kind of center shock should we fix. and after fixing should the spring be tensioned or let it be loose.
Beast
Hello there,
Hello Shuan.
What kind of stunt ?
Any spring should be pre-tension to some degree.
Brian
spyuggy
spring tension
Hi Shaun,
I don't know what kind of stunts you are trying, but the DN 01 isn;t the type of machine I would try stunts on.
The spring tension is better tried at medium first if you are going two up, if it bounces on the bends, then try going up one click at a time.
Good luck with it anyway:cool:
