Has anyone installed the JMB2003 CB Radio onto their DN-01? If so any details how you mounted it to handlebar? Antenna Mount ?
Hi Jim,
Let me know if you get any private responses as I'm about to do the same thing plus a Garmin Zumo GPS install.
I'm also adding the Givi tail rack and that's where I'm going to mount the antenna. Motorcycle Larry sells a neat looking mounting bracket that I have on my ST1300. The only bummer is the bracket extensions (used if you're using a wide Givi trunk) are out of stock. I'm going to use two main brackets for now, slightly more expensive but I can always retrofit in the future.
I've been test fitting the CB unit and the U-bolt that comes with the Zumo GPS will work to mount the bracket holding the CB in the normal place (lefthand grip). I'll probably have to shave 1/8" to 1/4" off the handlebar cover (ouch!) to fit the U-bolt and finding the right J&M bracket is a blind hunt. I have a bracket for the SilverWing and I can tell you it's close but not ideal.
The GPS looks like it might be best to mount in the center of the handlebars, but I might also try a suction cup mount on the tank.
I'll let you know my progress.
-Chief farkle mechanic and valet for Sukuta Girl
Hi Jim,
Small world- I'm a PC800 owner too. I'm only mounting the CB on Sukuta Girl's Dino because I just bought a ST1300 in July and it came already loaded with one. A lot of our riding friends have been bugging us to "upgrade" to CB, but to be honest, we've been happily using X1 Chatterboxes for years and I haven't been that impressed with the CB audio quality or constant fiddling.Thanks for the reply!
I had this JMB2003 on our PC-800 with plans to now use it on the DN-01. As with the PC-800 I am considering fabricating a mount from aluminum that would wrap partially back onto the plastic cover on the left handlebar, I think the one you are talking about trimming? However, the trimming idea sounds good too. I wish there was a reservoir on the left handlebar as the right, but since no clutch is needed that's the obvious. With the reservoir on the PC-800 it was simple to form an aluminum bracket and double stick tape it to the top of the reservoir. With the aluminum bent at the correct angle that put the PTT trigger right at the correct spot.
For your antenna mount, thats basically how I mounted the one on the PC-800 and it tested really, really good on SWR mounted like that. The Givi rack made for a good ground plane for the antenna.
We don't plan to use a GPS on this bike, however we will be installing a XM radio (small one) to feed into the JMB2003. I plan to use a R.A.M. mount installed on the top of that right side (front brake) reservoir. But I really like your location too, as to not be sticking up like a sore thumb!! I am going to look into that, maybe velcro so to be able to remove when not in use too?
Good luck with your installation!!
Small world! We have been using the Midland BT2 (bluetooth units) while riding our Dual Sports. However, we also have a GL-1800 Goldwing and ride alot with that group and if you want to stay in the loop, a CB is almost a must. So, if the wife is on her DN-01 with the group, I want her to be able to communicate with the pack too.Small world- I'm a PC800 owner too. I'm only mounting the CB on Sukuta Girl's Dino because I just bought a ST1300 in July and it came already loaded with one. A lot of our riding friends have been bugging us to "upgrade" to CB, but to be honest, we've been using happily using X1 Chatterboxes for years and I haven't been that impressed with the CB audio quality or constant fiddling.
