Burchsc
Reaching out to the community for thoughts on my attempt to get my Dino back on the road here’s a short history
While riding all of a sudden when taking off after a stop the bike had no power kind of like it did not go into low gear at the stop
I pulled over and turned the bike off hoping it would reset which it did then ran normally
I repeated this process several times in order to get to the dealer
Here’s the short history between me, my dealer, Honda customer support and Honda dealer technical support
Dealer - Hondamatic control unit replaced
oil pressure switch
they are asking us to do a Oil pressure test to see if the pressure is to high
The also want us to do a pin fitment check on the ECU & TCM
I also found out that no one at Honda is an expert at the DN-01 the guy who is helpping us is familiar with the Hondamatic transmission only not the hole bike
My first contact with Honda customer support below -
Description: Hello,
My dealer is not receiving timely support from Honda dealer technician services
My motorcycle has been in the shop for weeks and in this part of the country the riding season is short
Please expedite Honda dealer technical support for my case number Case ID # 16247561 to include sending a support technician onsite to my dealer
To be clear my dealer is doing a good job and trying to solve the issue but we need your help
Thanks
My second contact -
My dealers Case ID # 16247561, my case number 16316425
I am contacting your team again because there is no resolution to the issues with my 2009 DN-01
We need to identify the technical expertise within Honda that can support my dealership in implementing a solution
At this point the technician assigned by Honda is one who is experienced with Honda ATVs which have a similar transmission but not experienced with my particular machine
We are now playing a guessing game with the Honda technician suggesting the dealer try solutions without providing adequate reasoning, the result is an expensive witch hunt without solutions
The dealer is unwilling to continue this work without some well defined answers from Honda technical support
I am asking that Honda identify the proper technical resources to assist with the solution
Perhaps it would be well for Honda to look globally for these resources as my Honda motorcycle model has a higher popularity in the European and Asian markets
We would appreciate escalating our case to those within Honda with the authority to execute our request
To all - please share your thoughts…I’m out of options
TIA
oil pressure switch
Description: Hello,
Thanks
My second contact -
TIA
