ignition issue
plod202
when i started my DN-01 up this morning it stopped and then a single bar apeared on the display, several times i switched the ignition on and off but it would not start again, on about the 5th try i got it started, has anyone else had this issue, if so is it a sign of bigger problems:eek:
Bad fuel? Battery problems? Plugs/plug caps? Well, you should download the service manual and check how much blinks you have. Maybe you will find the answer.
Sorry, at this time, my answer for your question is "no".
plod202
thanks for that, just had it's service, fuel could be the issue will check out my manuel on the display bar see what it says.
Mine would not start the other day and was just blinking as well . I tried to start and nothing . I thought if I would turn the kill switch on and off and see if that would fix it . It did . The stupid kill switch was already on . When I turned it off , vrooooooom . 'doh
horobags
funny enough I did the same thing this morning with the kill switch, double doooh!!, 'download the service ' manual??? where can I do that??
